跳转到主内容
Kurio Touch 4S Battery Replacement
你所需要的
  1. Kurio Touch 4S Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Battery Replacement: 步骤 2 中的图像 1,3 Kurio Touch 4S Battery Replacement: 步骤 2 中的图像 2,3 Kurio Touch 4S Battery Replacement: 步骤 2 中的图像 3,3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Battery Replacement: 步骤 3 中的图像 1,3 Kurio Touch 4S Battery Replacement: 步骤 3 中的图像 2,3 Kurio Touch 4S Battery Replacement: 步骤 3 中的图像 3,3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
  4. Kurio Touch 4S Battery Replacement: 步骤 4 中的图像 1,1
    • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Battery Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool to remove the battery from its place.
    • The battery is glued into the device. So try removing it gently.
  6. Kurio Touch 4S Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the two wires using soldering tool to detach your bad battery from the device .
    • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
    • For more information on how to solder and desolder the wire Click here
结论
3等其他人完成本指南。
Khalid AlTamimi
于01/21/15注册
275 声望
创作了2篇指南
团队
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 的会员
USFT-BROWN-W15S6G5
3 名成员
创作了10篇指南
2条评论
do you know where to buy a replacement battery ?
Phil Bowring - 回复
Any idea where I can purchase a replacement battery?
Brooke Lonsdale - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 1,609
