跳转到主内容
Kurio Motion MotherBoard Replacement
你所需要的
  1. Kurio Motion MotherBoard Replacement, MotherBoard: 步骤 1 中的图像 1,1
    • Use the Phillips #0 Screwdriver to remove four 5mm screws from sides of the device.
  2. Kurio Motion MotherBoard Replacement: 步骤 2 中的图像 1,1
    • Use the Ifixit opening tool to pry open the device to remove the back of the Kurio Motion.
  3. Kurio Motion MotherBoard Replacement: 步骤 3 中的图像 1,1
    • Remove the tape covering the tape from the edges of the battery.
  4. Kurio Motion MotherBoard Replacement: 步骤 4 中的图像 1,1
    • Remove the orange connectors that are connected to the motherboard by lifting up the white tab, and then gently pulling the connector out.
  5. Kurio Motion MotherBoard Replacement: 步骤 5 中的图像 1,1
    • Take out the 5mm screws located at the top right and left of the motherboard.
  6. Kurio Motion MotherBoard Replacement: 步骤 6 中的图像 1,1
    • Remove the tape covering the camera gently.
  7. Kurio Motion MotherBoard Replacement: 步骤 7 中的图像 1,1
    • Use your spudger to carefully take out the camera.
  8. Kurio Motion MotherBoard Replacement: 步骤 8 中的图像 1,1
    • Use your soldering tool to solder the wires that are connected to the battery and the gray wire next them.
  9. Kurio Motion MotherBoard Replacement: 步骤 9 中的图像 1,1
    • Use your soldering tool to solder the wires that are connected to the speakers.
结论
Yazeed Ayyad
于09/10/23注册
447 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 82
