跳转到主内容
Kurio 7 Battery Replacement
你所需要的
  1. Kurio 7 Battery Replacement, Back Panel: 步骤 1 中的图像 1,3 Kurio 7 Battery Replacement, Back Panel: 步骤 1 中的图像 2,3 Kurio 7 Battery Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Begin by removing the rubber cover from the Kurio 7.
  2. Kurio 7 Battery Replacement: 步骤 2 中的图像 1,2 Kurio 7 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the four 30 mm Phillips #00 screws from the outer case.
  3. Kurio 7 Battery Replacement: 步骤 3 中的图像 1,2 Kurio 7 Battery Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
  4. Kurio 7 Battery Replacement: 步骤 4 中的图像 1,2 Kurio 7 Battery Replacement: 步骤 4 中的图像 2,2
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
  5. Kurio 7 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Use a credit card, or other thin object, to separate the battery from the screen.
    • Be sure to work the card slowly and carefully in order to not damage, break, or deform the battery.
  6. Kurio 7 Battery Replacement: 步骤 6 中的图像 1,1
    • Desolder, or separate using the desoldering braid, the marked areas on the motherboard to remove the old battery.
    • Refer to our soldering guide on how to solder and desolder.
结论
Solder in the new battery. To reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
Alex Powaser
于04/14/14注册
331 声望
创作了2篇指南
团队
Cal Poly, Team 12-36, Maness Spring 2014 Cal Poly, Team 12-36, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G36
4 名成员
创作了14篇指南
一条评论
Can the charging port be replaced in the kurio 7s tablet
Pamela Haughton - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 16,824
