当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn camera so the bottom is facing up and the front is facing away.
Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
Back cover is now unscrewed an can be removed.
Have the back of the camera facing up.
Unscrew the 6.2mm Phillips screw next to the viewfinder.
The back cover is now unscrewed. Lift up and pull the cover off evenly.
Desolder the two connections at the top of the flash capacitor.
If unfamiliar with soldering, refer to the guide 如何焊接和拆焊
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
