跳转到主内容
加入维修社区 - 创建账户
Kodak Easyshare C813 Memory Card Replacement
  1. Kodak Easyshare C813 Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
  2. Kodak Easyshare C813 Memory Card Replacement: 步骤 2 中的图像 1,3 Kodak Easyshare C813 Memory Card Replacement: 步骤 2 中的图像 2,3 Kodak Easyshare C813 Memory Card Replacement: 步骤 2 中的图像 3,3
    • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
  3. Kodak Easyshare C813 Memory Card Replacement: 步骤 3 中的图像 1,2 Kodak Easyshare C813 Memory Card Replacement: 步骤 3 中的图像 2,2
    • Locate memory card slot and insert memory card by inserting the gold terminals first.
    • Apply pressure into you feel it lock into place.
    • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
  4. Kodak Easyshare C813 Memory Card Replacement: 步骤 4 中的图像 1,2 Kodak Easyshare C813 Memory Card Replacement: 步骤 4 中的图像 2,2
    • Return the battery door to its formerly closed position.
  5. Kodak Easyshare C813 Memory Card Replacement: 步骤 5 中的图像 1,1
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G22
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 112
总计 10,866
