跳转到主内容
Kodak EasyShare M1033 LCD Screen Assembly Replacement
你所需要的
  1. Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: 步骤 1 中的图像 1,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: 步骤 1 中的图像 2,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: 步骤 1 中的图像 3,3
    • Ensure that the camera is powered off.
    • Turn the camera over so the battery compartment is facing up.
    • Place your thumb on the embossed surface of the battery latch, and push down and out until the latch releases.
    • Push down on the orange tab to release and remove the batteries.
    • Close the latch.
    • Let the camera sit for a minute to avoid electrical shock.
  2. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 2 中的图像 1,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 2 中的图像 2,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove six screws along the edge of the camera.
    • There are two screws next to the battery compartment
    • Two screws on the left side
    • Two screws on the right side
  3. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 3 中的图像 1,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 3 中的图像 2,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 3 中的图像 3,3
    • Use a spudger or your fingernail to pry the plastic case covering the LCD screen from the back of the camera.
  4. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to gently pry the LCD assembly and move it to reveal a ZIF connector.
    • Don't pull it off as it is connected by a ribbon cable.
    • Use your fingernail or the tip of the spudger to flip up the small locking flap.
    • Gently pull the cable out.
    • Remove the old LCD screen assembly.
  5. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 5 中的图像 1,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 5 中的图像 2,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 5 中的图像 3,3
    • Carefully insert the ribbon cable of the new LCD screen assembly into the ZIF connector and securely flip the lock down.
    • Ensure that the ribbon is secure.
    • Place the LCD screen assembly back into the original position.
  6. Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 6 中的图像 1,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 6 中的图像 2,3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: 步骤 6 中的图像 3,3
    • Place the back case on top of the new LCD screen.
    • Use the Phillips #00 screwdriver to replace the six screws along the edge of the camera that secure the back case.
    • Righty tighty.
结论
ntuong1117
于03/05/24注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 8-13, Grodsky Spring 2024 CSU Los Angeles, Team 8-13, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S8G13
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 44
总计 531
