简介
Remove damaged case and replace with new casing.
工具
配件
没有特定配件。
Using a Phillips #00 screwdriver, remove two (5.39 mm) screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located throughout the camera.
One (6.25 mm) screw is located on the top right corner, right to the "OK" button.
Four (4.45 mm) screws are on the bottom of the camera.
Two (2.95 mm) screws are on the left side of the camera, above the USB Port.
另外一个人完成了本指南。
