简介
This guide will help you gain access to the camera of the Kocaso M750B. Before considering repair make sure to visit the Kocaso M750B Troubleshooting page to make sure a replacement is necessary. Also make sure to work carefully because there are many parts that when damaged, are dangerous and costly.
你所需要的
Pry the battery up using the flat end of a spudger.
Remove the adhesive under the battery and carefully lift it up.
即将完成!
结论
