简介
This manual is for repairing the USB port of your e-reader. It can be used for any type of e-reader, but some steps will be slightly different. This example uses the Kobo Glo HD. An iFixit set was used for this repair, together with a soldering station that enlarges the image under a camera. This is recommended because the parts are very small.
你所需要的
All you have to do is lift the black locking arm that is keeping the ribbon cable in place. See picture.
Check the voltage of all six pins: if a pin shows no voltage level this probably means the pin is loose.
Use as much flux as possible (i.e. with the use of a flux marker).
A magnifying camera makes the job a lot easier.
Make sure that the pins are not touching each other.
Make sure that the e-reader functions properly before completely reassembling and closing it.
2等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
6条评论
Hello guys, two of the pins on my reader are broken and I can't find the exact micro usb b model to buy the replacement.
Do you recommend a website to get it from?
Thanks a lot for your help
There was one on Ebay
