当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Insert the back of a plastic opening tool into one of the beater holes.
Apply force to pull the circular plastic part off.
If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
Use a plastic opening tool to remove the speed knob.
Use a plastic opening tool to remove the long plastic piece
Use a plastic opening tool to remove the speed switch.
Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
Remove the bottom plastic piece using a plastic opening tool.
Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
Use your hands to remove the motor assembly.
Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
