跳转到主内容
加入维修社区 - 创建账户
Kitchen Faucet Replacement
你所需要的
  1. Kitchen Faucet Replacement, Kitchen Faucet: 步骤 1 中的图像 1,3 Kitchen Faucet Replacement, Kitchen Faucet: 步骤 1 中的图像 2,3 Kitchen Faucet Replacement, Kitchen Faucet: 步骤 1 中的图像 3,3
    • Rotate the hot and cold water valve knobs under the sink clockwise to turn off the water.
    • Turn on the faucet to relieve the pressure and any remaining water for about one minute.
  2. Kitchen Faucet Replacement: 步骤 2 中的图像 1,3 Kitchen Faucet Replacement: 步骤 2 中的图像 2,3 Kitchen Faucet Replacement: 步骤 2 中的图像 3,3
    • Place a bucket underneath the valves to catch dripping water.
    • Turn the hot and cold supply line nuts clockwise until the water supply lines come out.
    • For a pull-down faucet, disconnect the spray hose from both the spray head and the main body.
  3. Kitchen Faucet Replacement: 步骤 3 中的图像 1,3 Kitchen Faucet Replacement: 步骤 3 中的图像 2,3 Kitchen Faucet Replacement: 步骤 3 中的图像 3,3
    • Loosen and remove the nuts underneath the sink by using an adjustable wrench.
    • Remove the mounting bracket.
  4. Kitchen Faucet Replacement: 步骤 4 中的图像 1,2 Kitchen Faucet Replacement: 步骤 4 中的图像 2,2
    • Use your hands to pull the faucet out of the sink.
    • Clean away any grime or sealant with a cleaning spray and towel.
  5. Kitchen Faucet Replacement: 步骤 5 中的图像 1,3 Kitchen Faucet Replacement: 步骤 5 中的图像 2,3 Kitchen Faucet Replacement: 步骤 5 中的图像 3,3
    • Place the trim ring on the faucet hole.
    • Feed the faucet into the faucet hole and position it.
    • Different faucets install differently, so be sure to read and follow the instructions for your faucet.
  6. Kitchen Faucet Replacement: 步骤 6 中的图像 1,2 Kitchen Faucet Replacement: 步骤 6 中的图像 2,2
    • Underneath the sink, put the mounting bracket back in place, and turn the nuts to tighten them.
  7. Kitchen Faucet Replacement: 步骤 7 中的图像 1,3 Kitchen Faucet Replacement: 步骤 7 中的图像 2,3 Kitchen Faucet Replacement: 步骤 7 中的图像 3,3
    • Hook the water supply lines up by turning the hot and cold supply line nuts counter clockwise.
    • For pull-down faucets, attach the weight kit on the spray hose and connect it to both the spray head and the pull-out hose.
  8. Kitchen Faucet Replacement: 步骤 8 中的图像 1,3 Kitchen Faucet Replacement: 步骤 8 中的图像 2,3 Kitchen Faucet Replacement: 步骤 8 中的图像 3,3
    • Rotate the hot and cold water valve knobs counter clockwise to turn on the water under the sink.
    • Once it is all done, check if there are any leaks.
终点
2等其他人完成本指南。
Bongsu Kim
于09/16/20注册
184 声望
撰写一个指南
团队
1指南评论
Great guide on kitchen faucet replacement! I was able to follow the steps and successfully replace my old faucet with a new one. The pictures and detailed instructions made the process much easier. Thank you for sharing this useful information!
Scott Robillard - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 76
总计 1,347
