跳转到主内容
How to Repair a Broken Kitchen Faucet Pull-out Spray Head
你所需要的
  1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: 步骤 1 中的图像 1,2 How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: 步骤 1 中的图像 2,2
    • Located underneath the sink is the water-control valve.
    • Shut off the water supply by turning the water-control valve.
    • Not all water control values are the same so some nozzles may vary.
  2. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 步骤 2 中的图像 1,3 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 步骤 2 中的图像 2,3 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 步骤 2 中的图像 3,3
    • Pull on the kitchen spray head nozzle to reveal the connected hose.
    • Unscrew the kitchen faucet spray head nozzle counterclockwise off of the hose assembly.
  3. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 步骤 3 中的图像 1,2 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 步骤 3 中的图像 2,2
    • Remove the rubber gasket from the hose to reveal the c-clip.
    • Remove the c-clip that is located on the pull-out sprayer connection point with a small flat head screwdriver.
    • Do not discard the gasket. It can be reused unless damaged.
  4. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 步骤 4 中的图像 1,2 How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 步骤 4 中的图像 2,2
    • Pull on the sink faucet spray head from above the sink to find the main hose connection point to the water line located underneath the sink.
    • Unscrew the hose from the main faucet’s water line connection point.
    • A wrench may be necessary in order to loosen the nut.
    • Remove the hose from the sink sprayer location.
    • Connect the new hose by pressing it into the connection point. Then screw hose back on clockwise.
    • A wrench may be necessary in order to secure the end of the hose to the nut.
  5. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: 步骤 5 中的图像 1,1
    • Apply plumber's tape to the male threads on the new sink sprayer head to avoid leakage.
结论
2等其他人完成本指南。
Jodi Wright
于02/23/16注册
158 声望
撰写一个指南
团队
Texas Tech, Team 26-2, Rauch Spring 2016 Texas Tech, Team 26-2, Rauch Spring 2016 的会员
TTU-RAUCH-S16S26G2
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 89
总计 13,591
