简介
How to replace the connection cable on the Kingston HyperX CloudX Headset for Xbox One/Windows. Ensure the cable is the issue by plugging the headset into a compatible device and testing the sound. Move the cable near the base of the cable jack to see if any sound is produced:
- if so, you may proceed with this guide, but a cable jack replacement may also fix this issue.
- If no sound is produced, create the same wire movement around the base of the earphone where the wire makes contact with the headset. If any sound is produced, the connection cable replacement will fix this issue.
- If neither movement produces sound, the following are some possible issues:
- Complete cable disconnection
- The speakers are damaged
Note: This guide could still fix the complete cable disconnection issue, but until the new connection cable is installed, this issue is hard to diagnose, given NO power is delivered to the speakers/microphone.
你所需要的
Remove the microphone from the headset.
Remove the ear cushion on the earphone with the connection cable.
Carefully tug the edges of the cushion and ensure no tearing occurs.
For reassembly, follow Steps 1 and 2 in reverse order.
Prior knowledge of Soldering, working with wires, and multimeter usage is advised.
If no sound is produced after performing this guide, the following are some possible causes:
- Error performing the guide
- The new connection cable is defective
- Different connection cable from the original connection cable compatibility
- Example: 3 pole instead of 4 pole connection
- Possible speaker damage
If the problem still exists, a new headset may be necessary.
