当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
The adhesive is strong and may require an iOpener, or heat gun, to soften.
Remove the speaker bezel.
Remove the six pink 3mm T3 Torx screws from the back case.
Wedge opening picks around the perimeter between the display and back case.
Work the opening picks around the perimeter until the two halves disengage from each other.
Don't completely separate as the display ribbon cable still connects the two.
Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
Pry up the ribbon cable from the rear panel with the flat end of a spudger.
Remove the micro USB port and power button ribbon cable.
取消:我没有完成这个指南。
6等其他人完成本指南。
于01/29/17注册
70,583 声望
创作了50篇指南
徽章: 43
+ 40更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 44
总计 6,486
