跳转到主内容
Keyboard replacement on a why! W253EU
你所需要的
  1. Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 1,3 Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 2,3 Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: 步骤 1 中的图像 3,3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Keyboard replacement on a why! W253EU, Keyboard: 步骤 2 中的图像 1,3 Keyboard replacement on a why! W253EU, Keyboard: 步骤 2 中的图像 2,3 Keyboard replacement on a why! W253EU, Keyboard: 步骤 2 中的图像 3,3
    • Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
    • Insert a standard screwdriver into the slot in the cover above the keyboard.
    • Lift the cover with the usual care.
  3. Keyboard replacement on a why! W253EU: 步骤 3 中的图像 1,3 Keyboard replacement on a why! W253EU: 步骤 3 中的图像 2,3 Keyboard replacement on a why! W253EU: 步骤 3 中的图像 3,3
    • Use a Phillips # 1 screwdriver to remove the four screws securing the keyboard in the upper part.
  4. Keyboard replacement on a why! W253EU: 步骤 4 中的图像 1,2 Keyboard replacement on a why! W253EU: 步骤 4 中的图像 2,2
    • Turn the keyboard towards the screen.
    • Carefully remove the connection cable in the direction of the plug axis.
结论
For reassembly, follow the instructions in reverse order.
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
31,100 声望
创作了264篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 468
