跳转到主内容
Justin Bieber Concert Microphone On/Off Switch Replacement
你所需要的
  1. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: 步骤 1 中的图像 1,2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Flathead 1.5 mm Screwdriver
    $5.49
    购买
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing batteries: 步骤 2 中的图像 1,1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: 步骤 3 中的图像 1,2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: 步骤 3 中的图像 2,2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone On/Off Switch Replacement, Positioning device: 步骤 4 中的图像 1,1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: 步骤 5 中的图像 1,2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: 步骤 5 中的图像 2,2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  6. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: 步骤 6 中的图像 1,2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: 步骤 6 中的图像 2,2
    • Remove the 2, #8 11.7 mm Phillips Head screws on the On/Off Switch Board
  7. Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: 步骤 7 中的图像 1,2 Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: 步骤 7 中的图像 2,2
    • Remove On/Off Switch Board from its holding and detach the wires.
    • Replace the On/Off Switch Board with a new one and reattach the wires using this soldering guide
结论
Mike Seyman
于10/19/14注册
437 声望
创作了4篇指南
团队
Baylor, Team 4-1, Williams Fall 2014 Baylor, Team 4-1, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 155
