跳转到主内容
Jura Impressa S model front cover
你所需要的
  1. Jura Impressa S model front cover, How to open a Jura Impressa S model cover: 步骤 1 中的图像 1,2 Jura Impressa S model front cover, How to open a Jura Impressa S model cover: 步骤 1 中的图像 2,2
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
  2. Jura Impressa S model front cover: 步骤 2 中的图像 1,2 Jura Impressa S model front cover: 步骤 2 中的图像 2,2
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S model front cover: 步骤 3 中的图像 1,1
    • The top cover is now free. Lift ´er up and set ´er aside.
  4. Jura Impressa S model front cover, Jura Impressa S model front cover: 步骤 4 中的图像 1,2 Jura Impressa S model front cover, Jura Impressa S model front cover: 步骤 4 中的图像 2,2
    • Remove the knob for the steam valve by simply pulling it off.
    • The front cover is secured with a Torx T15 screw. Remove it.
  5. Jura Impressa S model front cover: 步骤 5 中的图像 1,1
    • Now the front cover can be opened like a door for a few inches. The hinge is on the left.
  6. Jura Impressa S model front cover: 步骤 6 中的图像 1,1
    • Various hoses hinder the further opening of the front cover. You need to remove the steam valve keypad from the cover.
    • Use a spudger to lift the two notches at the top of the front cover a bit to release the keypad at the top.
    • Lift the keypad upwards and pull it to the back. The steam pipe will slide out from its connection.
    • All hoses can remain connected.
  7. Jura Impressa S model front cover: 步骤 7 中的图像 1,1
    • Remove the silicone hose leading from the steam valve to the coffee spout. If it is secured with a cable tie which must be removed first.
    • The front cover is now free and can be opened.
结论
To reassemble your device, follow these instructions in reverse order
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
212,879 声望
创作了265篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
27 名成员
创作了1,209篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 720
