跳转到主内容
Jura Impressa S model Water Reservoir Seal Replacement
你所需要的
  1. Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: 步骤 1 中的图像 1,3 Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: 步骤 1 中的图像 2,3 Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: 步骤 1 中的图像 3,3
    • Remove the water reservoir.
    • Turn the Jura on its side to have access to the bottom plate
    • The water connector is protected by a plastic cover, which is secured by two plastic rivets.
    • Use some pliers and squeeze the rivets tightly and push them up until they release.
    • Carefully pry up the plastic cover.
    • Insert the new gasket with the flat side facing up.
    • Give some food-proof lubricant to the new seal and replace it.
结论
To reassemble your device, follow these steps in reverse order
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
210,196 声望
创作了255篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
26 名成员
创作了1,186篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 705
