跳转到主内容
Jabra Speak 510 Motherboard Replacement
你所需要的
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: 步骤 1 中的图像 1,2 Jabra Speak 510 Motherboard Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: 步骤 3 中的图像 1,2 Jabra Speak 510 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: 步骤 4 中的图像 1,3 Jabra Speak 510 Motherboard Replacement: 步骤 4 中的图像 2,3 Jabra Speak 510 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Jabra Speak 510 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: 步骤 6 中的图像 1,1
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: 步骤 7 中的图像 1,2 Jabra Speak 510 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
结论
4等其他人完成本指南。
Jordan Murphy
于02/16/16注册
717 声望
创作了3篇指南
团队
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S2G3
4 名成员
创作了8篇指南
3条评论
Great walk-through... thanks
Walaa Maher - 回复
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - 回复
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 76
总计 7,625
