跳转到主内容
Jabra Freeway Battery Replacement
你所需要的
  1. Jabra Freeway Battery Replacement, Front Panel: 步骤 1 中的图像 1,3 Jabra Freeway Battery Replacement, Front Panel: 步骤 1 中的图像 2,3 Jabra Freeway Battery Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
    • Remove the foam tape covering 2 hidden screws from the back of the device.
  2. Jabra Freeway Battery Replacement: 步骤 2 中的图像 1,3 Jabra Freeway Battery Replacement: 步骤 2 中的图像 2,3 Jabra Freeway Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Battery Replacement: 步骤 3 中的图像 1,3 Jabra Freeway Battery Replacement: 步骤 3 中的图像 2,3 Jabra Freeway Battery Replacement: 步骤 3 中的图像 3,3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Battery Replacement, Battery: 步骤 4 中的图像 1,2 Jabra Freeway Battery Replacement, Battery: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the rubber gasket using tweezers.
  5. Jabra Freeway Battery Replacement: 步骤 5 中的图像 1,2 Jabra Freeway Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the five 6mm T6 screws connecting the circuit board to the rear panel.
  6. Jabra Freeway Battery Replacement: 步骤 6 中的图像 1,3 Jabra Freeway Battery Replacement: 步骤 6 中的图像 2,3 Jabra Freeway Battery Replacement: 步骤 6 中的图像 3,3
    • Remove the microphone from microphone slot.
  7. Jabra Freeway Battery Replacement: 步骤 7 中的图像 1,3 Jabra Freeway Battery Replacement: 步骤 7 中的图像 2,3 Jabra Freeway Battery Replacement: 步骤 7 中的图像 3,3
    • Carefully use the plastic opening tool to lift the circuit board up.
  8. Jabra Freeway Battery Replacement: 步骤 8 中的图像 1,2 Jabra Freeway Battery Replacement: 步骤 8 中的图像 2,2
    • FIRE HAZARD. Avoid damaging the battery for this step!
    • Do not use a metal tool for this step.
    • Do not bend or puncture the battery!
    • There is adhesive covering the entire lower side of the battery.
    • Insert a guitar pick or thin plastic tool of some kind to detach the old battery from the case.
  9. Jabra Freeway Battery Replacement: 步骤 9 中的图像 1,1
    • Desolder the three wires connecting the battery.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
结论
6等其他人完成本指南。
Alec Wilson
于10/19/16注册
741 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-8, Catania Fall 2016 UMass Dartmouth, Team 4-8, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G8
2 名成员
创作了6篇指南
12指南评论
Hey Alec,
Why does your guide to replacing the battery in the Jabra Freeway say "no parts required"?
This would be much more useful if you provide a part number and source(s) for the replacement battery. And then maybe show removing the old battery and installing the new one.
Glenn C - 回复
Hi,
Does anyone knows a source for the compatible battery. Since Jabra Freeway battery has 3 wires, cannot find it online. I could find compatible batteries from China websites but they were with 2 wires.
Devesh Singh Senwal - 回复
I am sourcing replacement batteries for the jabra freeway should be in the end of april
scuba - 回复
any luck finding a replacement battery yet for this device???
chcastle - 回复
I’m looking for the batteries, 3 of them, right now 2018 06.
DavidNS - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 23
过去 30 天: 82
总计 7,653
