跳转到主内容
Jabra Freeway Antenna Replacement
你所需要的
  1. Jabra Freeway Antenna Replacement, Front Panel: 步骤 1 中的图像 1,3 Jabra Freeway Antenna Replacement, Front Panel: 步骤 1 中的图像 2,3 Jabra Freeway Antenna Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
    • Remove the foam tape covering 2 hidden screws from the back of the device.
  2. Jabra Freeway Antenna Replacement: 步骤 2 中的图像 1,3 Jabra Freeway Antenna Replacement: 步骤 2 中的图像 2,3 Jabra Freeway Antenna Replacement: 步骤 2 中的图像 3,3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Antenna Replacement: 步骤 3 中的图像 1,3 Jabra Freeway Antenna Replacement: 步骤 3 中的图像 2,3 Jabra Freeway Antenna Replacement: 步骤 3 中的图像 3,3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Antenna Replacement, Antenna: 步骤 4 中的图像 1,2 Jabra Freeway Antenna Replacement, Antenna: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Carefully remove the rubber gasket using the tweezers.
  5. Jabra Freeway Antenna Replacement: 步骤 5 中的图像 1,2 Jabra Freeway Antenna Replacement: 步骤 5 中的图像 2,2
    • Remove the five 6mm T6 screws connecting the circuit board to the rear panel.
  6. Jabra Freeway Antenna Replacement: 步骤 6 中的图像 1,3 Jabra Freeway Antenna Replacement: 步骤 6 中的图像 2,3 Jabra Freeway Antenna Replacement: 步骤 6 中的图像 3,3
    • Remove the microphone from microphone slot using tweezers.
  7. Jabra Freeway Antenna Replacement: 步骤 7 中的图像 1,3 Jabra Freeway Antenna Replacement: 步骤 7 中的图像 2,3 Jabra Freeway Antenna Replacement: 步骤 7 中的图像 3,3
    • Excessive force may cause the circuit board to break, destroying the device.
    • Carefully use the plastic opening tool to lift the circuit board up.
    • The orange portion of the circuit board is glued into place, and a small amount of force is necessary to break it free from the adhesive.
  8. Jabra Freeway Antenna Replacement: 步骤 8 中的图像 1,2 Jabra Freeway Antenna Replacement: 步骤 8 中的图像 2,2
    • Use the tweezers to remove the antenna from the retaining clips.
  9. Jabra Freeway Antenna Replacement: 步骤 9 中的图像 1,1
    • Desolder the antenna wire from the circuit board.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
结论
Alec Wilson
于10/19/16注册
741 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-8, Catania Fall 2016 UMass Dartmouth, Team 4-8, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G8
2 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 916
