跳转到主内容
Jabra Evolve2 65 Microphone Replacement
你所需要的
  1. Jabra Evolve2 65 Microphone Replacement, Ear Pads: 步骤 1 中的图像 1,1
    • Lay your headphones down on a flat, solid surface.
  2. Jabra Evolve2 65 Microphone Replacement: 步骤 2 中的图像 1,2 Jabra Evolve2 65 Microphone Replacement: 步骤 2 中的图像 2,2
    • Insert an opening tool into the seam between the ear pad and driver housing, near the hinge.
    • Gently pry the ear pad away from the driver housing until it releases.
  3. Jabra Evolve2 65 Microphone Replacement: 步骤 3 中的图像 1,2 Jabra Evolve2 65 Microphone Replacement: 步骤 3 中的图像 2,2
    • Pry off the other ear pad in the same manner.
  4. Jabra Evolve2 65 Microphone Replacement, Motherboard: 步骤 4 中的图像 1,2 Jabra Evolve2 65 Microphone Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Peel back the tape where the microphone's base connects to the headband.
    • Use a T6 Torx screwdriver to remove the single 2 mm screw.
  5. Jabra Evolve2 65 Microphone Replacement: 步骤 5 中的图像 1,1
    • Go about a third of the way around the first screw and peel back the tape to locate the second screw.
    • Use T6 Torx screwdriver to remove the single 2 mm screw.
  6. Jabra Evolve2 65 Microphone Replacement: 步骤 6 中的图像 1,1
    • Locate the third screw after peeling the tape off entirely after removing the second screw.
    • Use a T6 Torx screwdriver to remove the final 2 mm screw.
  7. Jabra Evolve2 65 Microphone Replacement: 步骤 7 中的图像 1,3 Jabra Evolve2 65 Microphone Replacement: 步骤 7 中的图像 2,3 Jabra Evolve2 65 Microphone Replacement: 步骤 7 中的图像 3,3
    • Use an opening tool to pry up and set aside the driver housing.
    • Gently remove the motherboard from the housing..
  8. Jabra Evolve2 65 Microphone Replacement: 步骤 8 中的图像 1,3 Jabra Evolve2 65 Microphone Replacement: 步骤 8 中的图像 2,3 Jabra Evolve2 65 Microphone Replacement: 步骤 8 中的图像 3,3
    • After locating the battery underneath, use a pair of tweezers to disconnect all connected cables.
    • Using tweezers, gently wiggle out the connector that joins the battery to the motherboard. The correct connector will be labeled on the motherboard and is the one that contains 2 wires, one black and one red.
  9. Jabra Evolve2 65 Microphone Replacement: 步骤 9 中的图像 1,1
    • Using a soldering iron, desolder the driver connections from the motherboard.
    • When reinstalling the driver to the motherboard, make sure you solder the driver connections to the correct terminals. The red wire goes to the "P" and the black wire goes to the "N."
  10. Jabra Evolve2 65 Microphone Replacement, Battery: 步骤 10 中的图像 1,3 Jabra Evolve2 65 Microphone Replacement, Battery: 步骤 10 中的图像 2,3 Jabra Evolve2 65 Microphone Replacement, Battery: 步骤 10 中的图像 3,3
    • Using an opening tool, gently pry out the battery.
  11. Jabra Evolve2 65 Microphone Replacement, Microphone: 步骤 11 中的图像 1,2 Jabra Evolve2 65 Microphone Replacement, Microphone: 步骤 11 中的图像 2,2
    • Hold the microphone arm in place tightly.
    • Twist the arm downwards and pull gently, but firmly until it comes off.
    • If microphone does not disconnect right away, wiggle the microphone arm slightly up and down until it pops out of place.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Lance Fernandes
于03/19/25注册
126 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-2, Botvin Spring 2025 UMass Dartmouth, Team 3-2, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S3G2
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 143
总计 769
