跳转到主内容
Jabra CRUISER2 Speaker Replacement
你所需要的
  1. Jabra CRUISER2 Speaker Replacement, Front Plate: 步骤 1 中的图像 1,1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener 指南
  2. Jabra CRUISER2 Speaker Replacement: 步骤 2 中的图像 1,1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Speaker Replacement: 步骤 3 中的图像 1,1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Jabra CRUISER2 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
  5. Jabra CRUISER2 Speaker Replacement: 步骤 5 中的图像 1,1
    • Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
    • The screwdriver sizes are located on the sides of their heads.
  6. Jabra CRUISER2 Speaker Replacement: 步骤 6 中的图像 1,1
    • Gently pull the black and red wires away from the back plate to remove the speaker.
  7. Jabra CRUISER2 Speaker Replacement: 步骤 7 中的图像 1,2 Jabra CRUISER2 Speaker Replacement: 步骤 7 中的图像 2,2
    • Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
结论
Spartacus
于10/17/14注册
636 声望
创作了5篇指南
团队
Baylor, Team 8-13, Williams Fall 2014 Baylor, Team 8-13, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G13
3 名成员
创作了5篇指南
5条评论
Is this a fairly standard speaker? With radio shack dead, can you suggest a source? Any specs? Yhanks
Brucereno2 - 回复
Did you ever find a speaker for your jabra cruiser?
Scot Tetreault -
halo
where i can get the new speaker for jabra cruiser 2?
Frantisek Fridrich - 回复
simple speaker in electronic parts shop 8ohm diameter 35mm price 1.2 €
A 36 mm speaker will also fit nicely. A 1 watt 8 ohms speaker is the best choice - the amplifier is not able to output enough power to drive a 2+ watt speaker.
Mobi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 1,886
