跳转到主内容
Jabra CRUISER2 Motherboard Replacement
你所需要的
  1. Jabra CRUISER2 Motherboard Replacement, Front Plate: 步骤 1 中的图像 1,1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener 指南
  2. Jabra CRUISER2 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Jabra CRUISER2 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the motherboard from the device by lifting it up from the back plate.
结论
Spartacus
于10/17/14注册
636 声望
创作了5篇指南
团队
Baylor, Team 8-13, Williams Fall 2014 Baylor, Team 8-13, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G13
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 789
