跳转到主内容
加入维修社区 - 创建账户
JBL Go 4 Outer Shell Replacement
你所需要的
  1. JBL Go 4 Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 1,3 JBL Go 4 Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 2,3 JBL Go 4 Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 3,3
    • Remove the speaker's grille by inserting the tip of an opening tool into the top corner, opposite the strap.
    • Slide the tool along the edge of the housing until it pops off. Place it to the side.
    • Be sure that the battery has been drained completely before attempting this replacement.
  2. JBL Go 4 Outer Shell Replacement: 步骤 2 中的图像 1,3 JBL Go 4 Outer Shell Replacement: 步骤 2 中的图像 2,3 JBL Go 4 Outer Shell Replacement: 步骤 2 中的图像 3,3
    • Insert the same opening tool in the opposite corner, lifting carefully.
    • Slide the tool along the edge until the cover pops off.
    • Gently pull the housing up and to the side.
    • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
  3. JBL Go 4 Outer Shell Replacement: 步骤 3 中的图像 1,1
    • At this point, you should switch over to the JBL Go 4 Battery Replacement, and follow the steps to remove the battery
    • Once the battery is removed, use a strong adhesive to adhere it to the new shell and follow the steps in reverse.
结论
Jackosn Caron
于03/20/25注册
255 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-1, Konn Spring 2025 UMass Dartmouth, Team 4-1, Konn Spring 2025 的会员
UMASSD-KONN-S25S4G1
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 74
总计 324
