跳转到主内容
JBL Go 3 Driver Replacement
你所需要的
  1. JBL Go 3 Driver Replacement, Driver: 步骤 1 中的图像 1,2 JBL Go 3 Driver Replacement, Driver: 步骤 1 中的图像 2,2
    • Hold the power button until the JBL Go 3 shuts off
    • Disconnect any charging cables
    • Use jimmy to remove the hard shell
    • Work your way around the edges slowly—be patient as it's glued or snapped in tightly
  2. JBL Go 3 Driver Replacement: 步骤 2 中的图像 1,3 JBL Go 3 Driver Replacement: 步骤 2 中的图像 2,3 JBL Go 3 Driver Replacement: 步骤 2 中的图像 3,3
    • Once the hard shell is removed,use jimmy to lift up the speaker part.
    • Locate the internal screws underneath the outer shell.
    • Use your precision screwdriver to remove all screws securing the plastic enclosure.
    • Carefully lift the casing to expose the speaker and other internal components.
  3. JBL Go 3 Driver Replacement: 步骤 3 中的图像 1,2 JBL Go 3 Driver Replacement: 步骤 3 中的图像 2,2
    • If accessible, unplug the battery to prevent any electrical short while working.
    • If it's soldered, proceed carefully and avoid touching metal contacts unnecessarily.
    • Unscrew any fasteners holding the speaker in place.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kasey Oliver
于03/18/25注册
507 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-5, Konn Spring 2025 UMass Dartmouth, Team 4-5, Konn Spring 2025 的会员
UMASSD-KONN-S25S4G5
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 26
总计 330
