跳转到主内容
加入维修社区 - 创建账户
JBL Flip 2 MicroUSB Port Replacement
你所需要的
  1. JBL Flip 2 MicroUSB Port Replacement, JBL Flip 2 Outer Case Disassembly: 步骤 1 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement, JBL Flip 2 Outer Case Disassembly: 步骤 1 中的图像 2,2
    • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
    • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
    添加评论
  2. JBL Flip 2 MicroUSB Port Replacement: 步骤 2 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
    询问修复机器人
    添加评论
  3. JBL Flip 2 MicroUSB Port Replacement: 步骤 3 中的图像 1,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 3 中的图像 2,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 3 中的图像 3,3
    • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
    • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
    • Gently slide the NFC chip into the device through the slot that the wire comes from.
    添加评论
  4. JBL Flip 2 MicroUSB Port Replacement: 步骤 4 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 4 中的图像 2,2
    • Peel the black rubber piece from one end to the other.
    询问修复机器人
    添加评论
  5. JBL Flip 2 MicroUSB Port Replacement: 步骤 5 中的图像 1,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 5 中的图像 2,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 5 中的图像 3,3
    • Remove the two 7.0 mm Phillips #1 screws.
    • Carefully detach the silver plastic cover by pulling both ends off.
    • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
    • Separate the silver plastic piece by pulling it off from the middle.
    添加评论
  6. JBL Flip 2 MicroUSB Port Replacement: 步骤 6 中的图像 1,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 6 中的图像 2,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 6 中的图像 3,3
    • Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
    • Repeat the same process for the 4 remaining metal nibs (two on each end).
    询问修复机器人
    添加评论
  7. JBL Flip 2 MicroUSB Port Replacement: 步骤 7 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 7 中的图像 2,2
    • Expand the metal casing and carefully slide it off the speaker.
    添加评论
  8. JBL Flip 2 MicroUSB Port Replacement: 步骤 8 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 8 中的图像 2,2
    • Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
    询问修复机器人
    添加评论
  9. JBL Flip 2 MicroUSB Port Replacement: 步骤 9 中的图像 1,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 9 中的图像 2,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 9 中的图像 3,3
    • Using the classic spudger, get underneath the black tape strips found on both side of the device.
    • After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
    • There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
    添加评论
  10. JBL Flip 2 MicroUSB Port Replacement: 步骤 10 中的图像 1,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 10 中的图像 2,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 10 中的图像 3,3
    • Wedge a spudger between the two halves where the tape was to pry the device open.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    询问修复机器人
    添加评论
  11. JBL Flip 2 MicroUSB Port Replacement: 步骤 11 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 11 中的图像 2,2
    • Use the black spudger to disconnect the speaker cord from it's socket.
    添加评论
  12. JBL Flip 2 MicroUSB Port Replacement: 步骤 12 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 12 中的图像 2,2
    • Use the black spudger to disconnect the auxiliary wire from its socket.
    添加评论
  13. JBL Flip 2 MicroUSB Port Replacement: 步骤 13 中的图像 1,1
    • Carefully remove the cable connecting the control chip to the motherboard.
    添加评论
  14. JBL Flip 2 MicroUSB Port Replacement: 步骤 14 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 14 中的图像 2,2
    • Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
    添加评论
  15. JBL Flip 2 MicroUSB Port Replacement: 步骤 15 中的图像 1,1
    • Carefully remove the cable connecting the nfc chip to the motherboard.
    询问修复机器人
    添加评论
  16. JBL Flip 2 MicroUSB Port Replacement, MicroUSB Port: 步骤 16 中的图像 1,1
    • Remove the 7.0 mm Philips #1 screw that connects the I/O board to the casing.
    询问修复机器人
    添加评论
  17. JBL Flip 2 MicroUSB Port Replacement: 步骤 17 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 17 中的图像 2,2
    • Remove the white ribbon cable that connects the I/O board to the motherboard.
    • Put the motherboard to the side.
    询问修复机器人
    添加评论
  18. JBL Flip 2 MicroUSB Port Replacement: 步骤 18 中的图像 1,2 JBL Flip 2 MicroUSB Port Replacement: 步骤 18 中的图像 2,2
    • With the black spudger, carefully wedge out the I/O board.
    • Be careful not to damage the I/O board with the black spudger.
    询问修复机器人
    添加评论
  19. JBL Flip 2 MicroUSB Port Replacement: 步骤 19 中的图像 1,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 19 中的图像 2,3 JBL Flip 2 MicroUSB Port Replacement: 步骤 19 中的图像 3,3
    • Gently pull the I/O board out from the speaker.
    添加评论
  20. JBL Flip 2 MicroUSB Port Replacement: 步骤 20 中的图像 1,1
    • Check out IFixit's official soldering guide for help with these special projects.
    • Pry off the loose MicroUSB port.
    • Use the soldering iron to solder the new MicroUSB port onto the I/O board.
    • Soldering iron will be very hot.
    添加评论
结论
取消:我没有完成这个指南。
15等其他人完成本指南。
Jonathan Wear
于02/09/16注册
1,276 声望
创作了5篇指南
团队
USF Tampa, Team 11-2, Cheng Spring 2016 USF Tampa, Team 11-2, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G2
4 名成员
创作了17篇指南
18指南评论
In my model MicroUSB is on separate board and both ports were covered by min. 20ml of hot-melt adhesive.
I spent hour on cables separation by sponge pieces - it is very important to use again hot glue to restore hermetic (!) speakers encloser, otherwise you get annoing sound of shaking cable.
101 - 回复 分享
Mine was like that too! %#*@ hot glue made it a pain to pull the usb out. sadly i need a new usb board... mine 2 pads were completely gone... not worth trying to even fix the contacts...
Sammy Morini - 回复 分享
Good clear guide, but as reported by other earlier, steps starting from 17 will be different in case I/O board with USB is a separate piece of board covered with glue. You need hot glue gun to reassemble the unit after replacing the USC socket. Guy in below link shows the struggle with the glue: https://www.youtube.com/watch?v=N6ahpRyK...
piotr.kaszyca - 回复 分享
Anywhere I can just buy the whole usb i/o board?
Charles Burgos - 回复 分享
Hi
Did you find it and where ?
Thank You
Marc BERGER - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 47
总计 55,825
