跳转到主内容
JBL Clip Plus Microphone Replacement
你所需要的
  1. JBL Clip Plus Microphone Replacement, Battery: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    $3.99
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Microphone Replacement: 步骤 2 中的图像 1,1
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Microphone Replacement: 步骤 3 中的图像 1,1
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Microphone Replacement: 步骤 4 中的图像 1,1
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Microphone Replacement: 步骤 5 中的图像 1,1
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Microphone Replacement: 步骤 6 中的图像 1,1
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Microphone Replacement: 步骤 7 中的图像 1,1
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Microphone Replacement: 步骤 8 中的图像 1,1
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Microphone Replacement: 步骤 9 中的图像 1,1
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Microphone Replacement: 步骤 10 中的图像 1,1
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
  11. JBL Clip Plus Microphone Replacement, Microphone: 步骤 11 中的图像 1,1
结论
另外一个人完成了本指南。
Noah Pauk
于02/08/16注册
809 声望
创作了3篇指南
团队
IUPUI, Team 3-4, Baechle Spring 2016 IUPUI, Team 3-4, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S3G4
4 名成员
创作了6篇指南
1指南评论
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
Mic - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 48
总计 2,143
