简介
This guide will focus on removing the microphone.
你所需要的
在这个步骤中使用的工具:Tweezers$3.99
Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
There are three solder points that need to be desoldered.
If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
Use a desolder tool to remove the solder to the microphone.
If you are unsure how to desolder these connections, refer to How To Solder and Desolder Connections
另外一个人完成了本指南。
一条评论
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
