跳转到主内容
JBL Clip Plus Battery Replacement
你所需要的
  1. JBL Clip Plus Battery Replacement, Battery: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    $3.99
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Battery Replacement: 步骤 2 中的图像 1,1
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Battery Replacement: 步骤 3 中的图像 1,1
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Battery Replacement: 步骤 4 中的图像 1,1
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Battery Replacement: 步骤 6 中的图像 1,1
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Battery Replacement: 步骤 7 中的图像 1,1
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Battery Replacement: 步骤 8 中的图像 1,1
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Battery Replacement: 步骤 9 中的图像 1,1
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Battery Replacement: 步骤 10 中的图像 1,1
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
结论
15等其他人完成本指南。
Noah Pauk
于02/08/16注册
809 声望
创作了3篇指南
团队
IUPUI, Team 3-4, Baechle Spring 2016 IUPUI, Team 3-4, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S3G4
4 名成员
创作了6篇指南
16指南评论
Is it possible if replaced with a battery from cellphones with higher AmH rating?
Patrick Ignacio - 回复
Unfortunately, it would be hard to find a cell battery this small. The original battery is 2" x 1 1/8" x 1/8". My samsung S3 battery is 2 1/2" x 2" x 3/16", so is far from fitting. If you were ok with shaving the molded battery holder down, you could probably fit one that's 2" x 1 1/2" x 1/4" or so (the thickness tolerance is hard to tell), but it would be a lot of work. I think I might just buy a speaker that has good battery reputation (i.e., NOT JBL).
Kael Lumen -
man need to replace the speaker were can i buy just that?
ruitherock - 回复
I think Id rather just buy a different speaker.
Lynne Norris - 回复
"No parts required."
Seriously? How about a new battery!
Also, mentioning the battery model or a link to a replacement battery would have been very useful.
Dan M - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 170
总计 27,606
