跳转到主内容
JBL Clip 2 Audio AUX Cord Replacement
你所需要的
  1. JBL Clip 2 Audio AUX Cord Replacement, Audio AUX Cord: 步骤 1 中的图像 1,1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Audio AUX Cord Replacement: 步骤 2 中的图像 1,1
    • There will be six 3 mm T8 screws under the cap, remove these six screws. Save
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Audio AUX Cord Replacement: 步骤 3 中的图像 1,1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Audio AUX Cord Replacement: 步骤 4 中的图像 1,1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Audio AUX Cord Replacement: 步骤 5 中的图像 1,1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Audio AUX Cord Replacement: 步骤 6 中的图像 1,1
结论
3等其他人完成本指南。
Michael Hong
于02/01/17注册
1,014 声望
创作了5篇指南
团队
UW Tacoma, Team 2-2, Rose Winter 2017 UW Tacoma, Team 2-2, Rose Winter 2017 的会员
UWT-ROSE-W17S2G2
4 名成员
创作了7篇指南
一条评论
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 29
总计 3,605
