跳转到主内容
JBL Charge 4 Speaker Replacement
你所需要的
  1. JBL Charge 4 Speaker Replacement, Speaker Grill: 步骤 1 中的图像 1,1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Speaker Replacement: 步骤 2 中的图像 1,2 JBL Charge 4 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Speaker Replacement: 步骤 3 中的图像 1,1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: 步骤 4 中的图像 1,2 JBL Charge 4 Speaker Replacement, Passive Bass Radiators: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Speaker Replacement: 步骤 5 中的图像 1,2 JBL Charge 4 Speaker Replacement: 步骤 5 中的图像 2,2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 JBL Charge 4 Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  7. JBL Charge 4 Speaker Replacement: 步骤 7 中的图像 1,1
    • Gently pull out the speaker.
  8. JBL Charge 4 Speaker Replacement: 步骤 8 中的图像 1,2 JBL Charge 4 Speaker Replacement: 步骤 8 中的图像 2,2
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
结论
10等其他人完成本指南。
Rohith Dara
于01/24/19注册
357 声望
撰写一个指南
团队
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 的会员
CPSU-WHITE-W19S1G1
4 名成员
创作了26篇指南
11条评论
Perfect - But where to get the replacement speaker ??? I’ve searched whole web. Please give me the info about replacement speaker diaphragm. Regards, T
Tadej Tomašič - 回复
Jbl charge 4 Led indicator board G ribbon cable authentic
carlos maltez - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 50
过去 30 天: 193
总计 22,526
