跳转到主内容
JBL Charge 4 Motherboard Replacement
你所需要的
  1. JBL Charge 4 Motherboard Replacement, Speaker Grill: 步骤 1 中的图像 1,1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Motherboard Replacement: 步骤 2 中的图像 1,2 JBL Charge 4 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Motherboard Replacement, Passive Bass Radiators: 步骤 4 中的图像 1,2 JBL Charge 4 Motherboard Replacement, Passive Bass Radiators: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Motherboard Replacement: 步骤 5 中的图像 1,2 JBL Charge 4 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Motherboard Replacement, Battery: 步骤 6 中的图像 1,2 JBL Charge 4 Motherboard Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the two 6mm Phillips #0 screws on the front side of the port bay cover.
  7. JBL Charge 4 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently slide the cover back and off the hooks.
    • Remove the port bay cover.
  8. JBL Charge 4 Motherboard Replacement: 步骤 8 中的图像 1,3 JBL Charge 4 Motherboard Replacement: 步骤 8 中的图像 2,3 JBL Charge 4 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Remove the two 6mm Phillips #0 screws.
    • Remove the four 8mm Phillips #0 screws.
  9. JBL Charge 4 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift up the battery cover.
  10. JBL Charge 4 Motherboard Replacement: 步骤 10 中的图像 1,3 JBL Charge 4 Motherboard Replacement: 步骤 10 中的图像 2,3 JBL Charge 4 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Remove the sticky tape to expose the white ribbon cable ZIF connector.
    • Flip up the black locking flap on the ZIF connector with the tip of a spudger or your fingernail to release the cable.
    • Remove the white ribbon cable from the battery cover and place the cover to the side.
  11. JBL Charge 4 Motherboard Replacement: 步骤 11 中的图像 1,2 JBL Charge 4 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the battery from the battery socket by gently pulling on it.
  12. JBL Charge 4 Motherboard Replacement: 步骤 12 中的图像 1,3 JBL Charge 4 Motherboard Replacement: 步骤 12 中的图像 2,3 JBL Charge 4 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Pull out the battery enough to expose the battery's wire connector.
    • Push down on the white tab and gently pull out the battery-device connector.
  13. JBL Charge 4 Motherboard Replacement, Speaker: 步骤 13 中的图像 1,2 JBL Charge 4 Motherboard Replacement, Speaker: 步骤 13 中的图像 2,2
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  14. JBL Charge 4 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Gently pull out the speaker.
  15. JBL Charge 4 Motherboard Replacement: 步骤 15 中的图像 1,2 JBL Charge 4 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
  16. JBL Charge 4 Motherboard Replacement, Motherboard: 步骤 16 中的图像 1,3 JBL Charge 4 Motherboard Replacement, Motherboard: 步骤 16 中的图像 2,3 JBL Charge 4 Motherboard Replacement, Motherboard: 步骤 16 中的图像 3,3
    • Remove the wire harness coming from the port bay on the left side of the motherboard by gently lifting the connector from its housing.
    • Remove the white ribbon cable from the ZIF connector by lifting the black locking flap on the connector with a spudger or your fingernail.
  17. JBL Charge 4 Motherboard Replacement: 步骤 17 中的图像 1,2 JBL Charge 4 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Remove the ground cable harness next to the speaker wire by gentling pulling it from the connector.
  18. JBL Charge 4 Motherboard Replacement: 步骤 18 中的图像 1,2 JBL Charge 4 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Flip the speaker around to the other side.
    • Remove the wiring harness leading to the port bay by pressing down on the tab and gently pulling the harness from the connector.
  19. JBL Charge 4 Motherboard Replacement: 步骤 19 中的图像 1,3 JBL Charge 4 Motherboard Replacement: 步骤 19 中的图像 2,3 JBL Charge 4 Motherboard Replacement: 步骤 19 中的图像 3,3
    • Push the motherboard from either side of the housing along its tracks.
    • Pull out the motherboard from the speaker housing.
    • When putting the motherboard back in the housing, ensure that it is between the two tracks on the top side of the speaker.
结论
11等其他人完成本指南。
Zachary Colwell
于01/24/19注册
1,914 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 的会员
CPSU-WHITE-W19S1G1
4 名成员
创作了26篇指南
4条评论
Where i could buy a replacement motherboard for jbl charge 4?thank you.
bbt8mikael_06 - 回复
This guide has a vital flaw. Just look at the loose wire cause by a broken solder in image 16!
PAJ 101 - 回复
that's the antenna cable which was pulled out of the connector. The step of popping the antenna connector out is missing.
Dan Glogoveanu -
from where i buy or replace the motherboard of jbl charge 4?
Aman Bisht - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 52
过去 30 天: 221
总计 12,476
