跳转到主内容
JBL Charge 4 Charging Port Bay Replacement
你所需要的
  1. JBL Charge 4 Charging Port Bay Replacement, Speaker Grill: 步骤 1 中的图像 1,1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Charging Port Bay Replacement: 步骤 2 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement: 步骤 2 中的图像 2,2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Charging Port Bay Replacement: 步骤 3 中的图像 1,1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Charging Port Bay Replacement, Passive Bass Radiators: 步骤 4 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement, Passive Bass Radiators: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Charging Port Bay Replacement: 步骤 5 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement: 步骤 5 中的图像 2,2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Charging Port Bay Replacement, Charging Port Bay: 步骤 6 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement, Charging Port Bay: 步骤 6 中的图像 2,2
    • Remove the two 6mm Phillips #0 screws from either side to remove the port bay cover.
  7. JBL Charge 4 Charging Port Bay Replacement: 步骤 7 中的图像 1,1
    • There are two hooks that attach the opposite side of the port bay cover to the device. Slide the cover back and off the hooks.
    • Remove the port bay cover.
  8. JBL Charge 4 Charging Port Bay Replacement: 步骤 8 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement: 步骤 8 中的图像 2,2
    • Remove the six 6mm Phillips #0 screws.
  9. JBL Charge 4 Charging Port Bay Replacement: 步骤 9 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement: 步骤 9 中的图像 2,2
    • Before removing port bay you must detach the connecting tabs on either side of the device.
    • Press on the tab and gently pull out the wire connector.
  10. JBL Charge 4 Charging Port Bay Replacement: 步骤 10 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement: 步骤 10 中的图像 2,2
    • Remove the second connector on the opposite side by gently pulling it out.
  11. JBL Charge 4 Charging Port Bay Replacement: 步骤 11 中的图像 1,1
    • Remove the port bay from the device and place the device to the side.
  12. JBL Charge 4 Charging Port Bay Replacement: 步骤 12 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement: 步骤 12 中的图像 2,2
    • Remove the three 9mm Phillips #0 screws from the board.
  13. JBL Charge 4 Charging Port Bay Replacement: 步骤 13 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement: 步骤 13 中的图像 2,2
    • Using the plastic opening tool, lift the board from the port bay holder.
  14. JBL Charge 4 Charging Port Bay Replacement: 步骤 14 中的图像 1,2 JBL Charge 4 Charging Port Bay Replacement: 步骤 14 中的图像 2,2
    • Choose which port you want to replace.
    • Turn the board around and desolder the connection to remove the chosen port.
    • A guide for soldering and desoldering can be found here.
结论
12等其他人完成本指南。
Zachary Colwell
于01/24/19注册
1,914 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 的会员
CPSU-WHITE-W19S1G1
4 名成员
创作了26篇指南
9条评论
Does anybody know which exact ports I have to get? There are a ton of different models out there.
Ulpi - 回复
You can purchase charging sockets from ebay by searching for "jbl charge 4 usb-c port" (without the quotation marks) or if you don't feel like replacing the charging port yourself, there are mail-in repair services available also.
Simon -
Ijust change the battery on my jbl charge4 it is not powering on or even charging what going on?
pipask1 - 回复
Ersatzteil:
✅ JBL Charge 4 Bluetooth Lautsprecher Micro USB C Buchse Ladebuchse Connector
https://www.ebay.de/itm/164897748374
Falls Sie beim Austausch der Buchse Hilfe benötigen:
✅ REPARATUR Austausch Micro USB C Buchse Ladebuchse Anschluss Port JBL Charge 4
https://www.ebay.de/itm/164975006896
PC-Solutions - 回复
I could not change the USB-C myself so had it soldered in a shop for me. For the rest of the procedure, I could perform it alone thanks to this guide, now the device works again. Thanks!
sylkys - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 58
过去 30 天: 275
总计 22,509
