跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
JBL Charge 3 前部面板更换
你所需要的
  1. JBL Charge 3 前部面板更换, 前部面板: 步骤 1 中的图像 1,3 JBL Charge 3 前部面板更换, 前部面板: 步骤 1 中的图像 2,3 JBL Charge 3 前部面板更换, 前部面板: 步骤 1 中的图像 3,3
    • 将你的扬声器上下颠倒然后将塑料撬棍垂直塞入前部面板的缝隙中。
    • 慢慢向外拉动塑料撬棍来撬开固定它的四个卡扣。
    • 在四个边缘都重复这个步骤。
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - 回复
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - 回复
    There are two Phillips head screws to remove before prying the cover off
    jason - 回复
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - 回复
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - 回复
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - 回复
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - 回复
    How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
    Bukowski101 - 回复
  2. JBL Charge 3 前部面板更换: 步骤 2 中的图像 1,1
    • 轻轻地从两侧拽开,并且从扬声器外壳移除。
    • 前部面板的内部有为了重新组装而必须与在扬声器外壳的销对应的洞。
    • 移除前部面板并不会影响设备的防水密封。然而,任何进一步的拆解都需要你移除防水密封和垫片。在这些被改动之后,你的设备可能不再防水。
    Include dissembling the plastic cover? cover?
    KanGoon - 回复
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Frank Puranik - 回复
    Very good guide! Pics and descriptions make this easy!
    John G Petko - 回复
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - 回复
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - 回复
    Well, broke off the cover tabs. Have to remove 2 screws first. Might add that to the instructions.🤔
    Spartacus - 回复
    Me too. Saw the screws after I'd popped it off.
    Del Taylor -
    It doesn't look fixable. Can't get the cover to stay on anymore. Ideas?
    Del Taylor - 回复
结论
通过执行相反顺序的步骤来重新组装你的设备。
6等其他人完成本指南。
由衷感谢以下译者:
en zh
83%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Aidan Hays
于10/08/18注册
4,050 声望
创作了2篇指南
团队
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 的会员
CPSU-WHITE-F18S13G1
3 名成员
创作了26篇指南
2条评论
where can i buy a new front cover for mine? mine has got cracked
Cammy Innes - 回复
It seems there may be different versions of Charge 3 covers in existence, as when I opened mine (carefully with a slim screwdriver) I was presented with a single cross head screw on each end which was holding one of the ends of the cover in place. I could remove the top end at both ends, but had to unscrew these screws to get the other end off. It was easy, just deviates from this guide quite a bit!
Thomas Hall - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 26
过去 30 天: 139
总计 10,266
