跳转到主内容
Instant Pot 60 EPC Button Panel Replacement
你所需要的
  1. Instant Pot 60 EPC Button Panel Replacement, Button Panel: 步骤 1 中的图像 1,3 Instant Pot 60 EPC Button Panel Replacement, Button Panel: 步骤 1 中的图像 2,3 Instant Pot 60 EPC Button Panel Replacement, Button Panel: 步骤 1 中的图像 3,3
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Button Panel Replacement: 步骤 2 中的图像 1,2 Instant Pot 60 EPC Button Panel Replacement: 步骤 2 中的图像 2,2
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Button Panel Replacement: 步骤 3 中的图像 1,2 Instant Pot 60 EPC Button Panel Replacement: 步骤 3 中的图像 2,2
    • In order to reach the circuit board you'll need to remove the secondary frame surrounding it.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
  4. Instant Pot 60 EPC Button Panel Replacement: 步骤 4 中的图像 1,2 Instant Pot 60 EPC Button Panel Replacement: 步骤 4 中的图像 2,2
    • Disconnect the 8x1 pin control connector from the main board.
    • The plug should easily come up when pulled with slight pressure.
    • It may be helpful to also rock the plug side to side while pulling up.
  5. Instant Pot 60 EPC Button Panel Replacement: 步骤 5 中的图像 1,1
    • Remove the single screw attaching the front panel to the main body with a Phillips screwdriver.
    • This screw may be difficult to get to; we were able to remove it by threading a screwdriver underneath the main board.
  6. Instant Pot 60 EPC Button Panel Replacement: 步骤 6 中的图像 1,3 Instant Pot 60 EPC Button Panel Replacement: 步骤 6 中的图像 2,3 Instant Pot 60 EPC Button Panel Replacement: 步骤 6 中的图像 3,3
    • Remove the main body from the Instant Pot.
    • It should easily pull up with a little force and be free from the control board.
  7. Instant Pot 60 EPC Button Panel Replacement: 步骤 7 中的图像 1,2 Instant Pot 60 EPC Button Panel Replacement: 步骤 7 中的图像 2,2
    • Remove the Phillips screw.
  8. Instant Pot 60 EPC Button Panel Replacement: 步骤 8 中的图像 1,2 Instant Pot 60 EPC Button Panel Replacement: 步骤 8 中的图像 2,2
    • Pull the front panel away from the body and carefully pull out the wires that connect the front panel to the circuit board.
    • The front panel is now free to be replaced.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 49
总计 402
