跳转到主内容
加入维修社区 - 创建账户
Installing Sewing Machine Bobbin
你所需要的
  1. Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: 步骤 1 中的图像 1,2 Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: 步骤 1 中的图像 2,2
    • Use your finger to open the bobbin door below the presser foot.
    询问修复机器人
    添加评论
  2. Installing Sewing Machine Bobbin: 步骤 2 中的图像 1,2 Installing Sewing Machine Bobbin: 步骤 2 中的图像 2,2
    • Align the hole in the bobbin spindle over the peg in the bobbin case.
    • Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
    • Take the loose thread end and slide it through the slit on the side of the bobbin case.
    添加评论
  3. Installing Sewing Machine Bobbin: 步骤 3 中的图像 1,2 Installing Sewing Machine Bobbin: 步骤 3 中的图像 2,2
    • Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
    询问修复机器人
    添加评论
  4. Installing Sewing Machine Bobbin: 步骤 4 中的图像 1,2 Installing Sewing Machine Bobbin: 步骤 4 中的图像 2,2
    • Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
    • Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
    询问修复机器人
    添加评论
  5. Installing Sewing Machine Bobbin: 步骤 5 中的图像 1,2 Installing Sewing Machine Bobbin: 步骤 5 中的图像 2,2
    • Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
    • Align the metal arm on the bobbin case so that it sits in the slot in the machine.
    • Release the bobbin case.
    询问修复机器人
    添加评论
  6. Installing Sewing Machine Bobbin: 步骤 6 中的图像 1,2 Installing Sewing Machine Bobbin: 步骤 6 中的图像 2,2
    • Close the door on the compartment below the presser foot.
    添加评论
终点
取消:我没有完成这个指南。
7等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,988 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了31,897篇指南
2指南评论
Love it! Thank you for posting this as my wife has had to fix things on her sewing machine and it's good to have a reference other than Youtube where you can sit down and read it and make adjustments accordingly!
Alex - 回复 分享
Thank you for giving a good detailed answer that I had with the insertion of the bobbin on the sewing machine. I took a crash course today, came home and this evening decided to go through what I had learned and ran into a snag. I was able to overcome what was incorrect. Again, thanks a bunch 🧵
Felicia Jones - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 71
过去 30 天: 324
总计 60,499
