跳转到主内容
Installing Hook-and-Loop Tape in Clothing
你所需要的
  1. Installing Hook-and-Loop Tape in Clothing, Installing Hook-and-Loop Tape in Clothing: 步骤 1 中的图像 1,2 Installing Hook-and-Loop Tape in Clothing, Installing Hook-and-Loop Tape in Clothing: 步骤 1 中的图像 2,2
    • Lay your piece of hook-and-loop tape on the fabric where you would like it to live.
    • Pin the hook-and-loop tape into place.
  2. Installing Hook-and-Loop Tape in Clothing: 步骤 2 中的图像 1,2 Installing Hook-and-Loop Tape in Clothing: 步骤 2 中的图像 2,2
    • Position your fabric under the presser foot of your sewing machine in the upper right hand corner of the hook-and-loop tape. Drop the presser foot.
    • Use the balance wheel to sink the needle.
    • The balance wheel should only be turned in the direction that advances the sewing machine. Usually, this means turning the wheel towards you. Turning the wheel in the opposite direction can ruin the tension on the sewing machine, causing it to jam. See your sewing machine manual for instructions specific to your machine.
  3. Installing Hook-and-Loop Tape in Clothing: 步骤 3 中的图像 1,3 Installing Hook-and-Loop Tape in Clothing: 步骤 3 中的图像 2,3 Installing Hook-and-Loop Tape in Clothing: 步骤 3 中的图像 3,3
    • Sew along the edge of the hook-and-loop tape, stopping just at the end.
    • Pull the pin out.
    • When you pull the pin out, be sure the needle is already down. If not, use the balance wheel to sink the needle into the fabric.
  4. Installing Hook-and-Loop Tape in Clothing: 步骤 4 中的图像 1,3 Installing Hook-and-Loop Tape in Clothing: 步骤 4 中的图像 2,3 Installing Hook-and-Loop Tape in Clothing: 步骤 4 中的图像 3,3
    • Lift the presser foot, leaving the needle sunk.
    • Rotate the fabric 90º counterclockwise.
  5. Installing Hook-and-Loop Tape in Clothing: 步骤 5 中的图像 1,2 Installing Hook-and-Loop Tape in Clothing: 步骤 5 中的图像 2,2
    • Lower the presser foot and sew the second side of the hook-and-loop tape.
    • Continue sewing the hook-and-loop tape. When you come to the end of a side, sink the needle into the fabric and lift the presser foot. Then turn the fabric at each of the remaining corners.
  6. Installing Hook-and-Loop Tape in Clothing: 步骤 6 中的图像 1,2 Installing Hook-and-Loop Tape in Clothing: 步骤 6 中的图像 2,2
    • On the last side of the hook-and-loop tape, backstitch over the last few stitches.
  7. Installing Hook-and-Loop Tape in Clothing: 步骤 7 中的图像 1,3 Installing Hook-and-Loop Tape in Clothing: 步骤 7 中的图像 2,3 Installing Hook-and-Loop Tape in Clothing: 步骤 7 中的图像 3,3
    • Clip the threads, freeing the fabric from the sewing machine.
    • Clip the extra thread off.
    • Repeat this guide for the other side of the hook-and-loop tape.
终点
Brittany McCrigler
于03/05/12注册
90,487 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,788篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 49
过去 30 天: 186
总计 37,295
