跳转到主内容
加入维修社区 - 创建账户
Insignia NS-CSPBTHOL-R Buttons Replacement
你所需要的
  1. Insignia NS-CSPBTHOL-R Buttons Replacement, Buttons: 步骤 1 中的图像 1,2 Insignia NS-CSPBTHOL-R Buttons Replacement, Buttons: 步骤 1 中的图像 2,2
    • Use the spudger to pry off the plastic grate covering the speakers, then gently pull it off with your fingers.
  2. Insignia NS-CSPBTHOL-R Buttons Replacement: 步骤 2 中的图像 1,1
    • once the grate has been removed, Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  3. Insignia NS-CSPBTHOL-R Buttons Replacement: 步骤 3 中的图像 1,1
    • Insert the Spudger between the corners of base and the face of the speaker to open the device. The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
  4. Insignia NS-CSPBTHOL-R Buttons Replacement: 步骤 4 中的图像 1,3 Insignia NS-CSPBTHOL-R Buttons Replacement: 步骤 4 中的图像 2,3 Insignia NS-CSPBTHOL-R Buttons Replacement: 步骤 4 中的图像 3,3
    • Gently pull apart the speaker to separate the speakers from the battery and motherboard. Then pull out the motherboard with your fingers by grabbing the edges and pulling upwards.
  5. Insignia NS-CSPBTHOL-R Buttons Replacement: 步骤 5 中的图像 1,2 Insignia NS-CSPBTHOL-R Buttons Replacement: 步骤 5 中的图像 2,2
    • Desolder the four contact points from the button that is unresponsive.
    • Check out this helpful guide for soldering and desoldering tips.
结论
Zachary Foltz
于02/15/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team 12-6, Eyestone Spring 2017 USF Tampa, Team 12-6, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G6
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 467
