简介
This guide will teach you how to replace your device's speakers.
你所需要的
Unplug and remove the power cord. Turn the boombox upside down.
Grip the sides of the case and use your thumbs to pop open the battery cover.
Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
This red wire will now be loose and you can move it out of the antenna base slot.
Unscrew the four 12.5mm screws with the Phillips PH1 Screwdriver.
Unscrew the one 10mm long screw with the Phillips PH1 Screwdriver.
Remove the four 8.5mm chrome screws from the front panel with the Phillips PH1 screwdriver.
Unsolder the two wires at the given points. If you need help soldering, see this guide.
The left speaker (shown) has a yellow wire on the positive (+) end, and an orange wire on the negative (-) end.
The right speaker (not shown) has a brown wire on the positive (+) end, and a red wire on the negative (-) end.
