简介
If your tablet display is not functioning or the image is distorted, you may need to replace the screen.
你所需要的
Use a plastic opening tool to remove the rear panel from the front case.
Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
Work the tool around the perimeter of the device until the front and rear panels become separate.
即将完成!
结论
