跳转到主内容
加入维修社区 - 创建账户
Infinity v2 10.1 Motherboard Replacement
浏览量: 1841
浏览统计数据:
过去24小时
2
过去 7 天:
17
过去 30 天:
70
总计
1,841
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 1
1 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 50分钟
难度: 困难
You may have to replace the Infinity v2 10.1 motherboard if the device no longer turns on and works. This process requires a soldering iron, so make sure to follow all the safety warnings and instructions in this guide and in the instructions of your soldering iron. You may be able to replace the motherboard without fully removing the battery from the LCD display, depending on what needs to be fixed on your device. Only remove the battery completely if you need to access the LCD as well.
你所需要的
工具
    1. Infinity v2 10.1 Motherboard Replacement, Back Case: 步骤 1 中的图像 1,3 Infinity v2 10.1 Motherboard Replacement, Back Case: 步骤 1 中的图像 2,3 Infinity v2 10.1 Motherboard Replacement, Back Case: 步骤 1 中的图像 3,3
      • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
      • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
      • There will be a slight click noise as you free each tab.
      • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
      询问修复机器人
      添加评论
    2. Infinity v2 10.1 Motherboard Replacement: 步骤 2 中的图像 1,2 Infinity v2 10.1 Motherboard Replacement: 步骤 2 中的图像 2,2
      • Remove the speakers from the case by gently lifting them up and out of their slots.
      询问修复机器人
      添加评论
    1. Infinity v2 10.1 Motherboard Replacement, Battery: 步骤 3 中的图像 1,3 Infinity v2 10.1 Motherboard Replacement, Battery: 步骤 3 中的图像 2,3 Infinity v2 10.1 Motherboard Replacement, Battery: 步骤 3 中的图像 3,3
      • Pry beneath each side of the battery using a spudger.
      • The adhesive may be too strong to manually remove, so heat can be applied using the iOpener. This evenly heats the adhesive and allows the battery to be lifted away easier. Do not place the iOpener directly on the battery; always apply heat on the opposite side of the device.
      • You may use a blow-dryer on a cool setting. Keep the dryer moving and at least 6 inches from the battery to prevent dangerous bubbling of the battery due to excess heat.
      询问修复机器人
      添加评论
    2. Infinity v2 10.1 Motherboard Replacement: 步骤 4 中的图像 1,2 Infinity v2 10.1 Motherboard Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Desolder the red and black wires connecting the battery to the motherboard.
      • Once the solder is melted, use tweezers to remove both wires from the motherboard.
      • The solder and iron will be extremely hot. Use tweezers to grab the wire to avoid burning your fingers from accidental contact with the iron.
      询问修复机器人
      添加评论
    1. Infinity v2 10.1 Motherboard Replacement, Speakers: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • Turn on your soldering iron and allow it to heat up. Once it is hot, press the tip of the iron to the both of the solder points that attach the wires to the motherboard until the solder is melted.
      • Once the solder is melted, use tweezers to remove the wires from the motherboard.
      • The solder and iron will be extremely hot. You can use tweezers to grab the wire to avoid burning your fingers from accidental contact with the iron.
      询问修复机器人
      添加评论
    1. Infinity v2 10.1 Motherboard Replacement, Camera: 步骤 6 中的图像 1,1
      • Use your thumb or opening tool to lift the black connector holding in the ribbon cable.
      询问修复机器人
      添加评论
    2. Infinity v2 10.1 Motherboard Replacement: 步骤 7 中的图像 1,1
      • Remove the camera by gently picking it up and pulling it free from the connector.
      • Avoid touching the lens of either camera.
      询问修复机器人
      添加评论
    1. Infinity v2 10.1 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 Infinity v2 10.1 Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
      • Remove the camera from the device by using your thumb or prying tool to lift the black connector holding in the ribbon cable.
      • Remove the camera by gently picking it up and pulling it free from the connector. Avoid touching the lens of either camera.
      询问修复机器人
      添加评论
    2. Infinity v2 10.1 Motherboard Replacement: 步骤 9 中的图像 1,1
      • Use your finger to lift the black connectors on each ribbon cable. Remove both ribbon cables that connect the two screens to the motherboard by pulling them out of the connectors.
      询问修复机器人
      添加评论
    3. Infinity v2 10.1 Motherboard Replacement: 步骤 10 中的图像 1,3 Infinity v2 10.1 Motherboard Replacement: 步骤 10 中的图像 2,3 Infinity v2 10.1 Motherboard Replacement: 步骤 10 中的图像 3,3
      • Remove three JIS #0 screws that hold the motherboard to the screen.
      询问修复机器人
      添加评论
    4. Infinity v2 10.1 Motherboard Replacement: 步骤 11 中的图像 1,1
      • Remove the motherboard by simply lifting it up off the LCD.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
sammytarbokas
于10/31/19注册
193 声望
创作了2篇指南
团队
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 UMass Dartmouth, Team S2-G4, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S2G4
3 名成员
创作了72篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 70
总计 1,841
