简介
If the monitor of the Infant Optics DXR-8 is not functioning properly, the motherboard may be faulty. Follow these instructions to replace the motherboard in the monitor.
你所需要的
Using the plastic opening tool, remove screen protector from front of monitor.
Using a plastic opening tool, disconnect the ribbon cable connector.
Gently separate the ribbon cable from the motherboard.
Flip the motherboard away from the case.
Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
另外一个人完成了本指南。
2条评论
Can you please tell me where to buy a replacement motherboard??
