跳转到主内容
IdeaPad Yoga 13 Charging Port Replacement
你所需要的
  1. IdeaPad Yoga 13 Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Remove all ten screws using the T4 Torx screwdriver.
    • Remove the back cover from the device.
  2. IdeaPad Yoga 13 Charging Port Replacement: 步骤 2 中的图像 1,2 IdeaPad Yoga 13 Charging Port Replacement: 步骤 2 中的图像 2,2
    • Use the blue opening tool to further separate the keyboard bezel.
    • Carefully apply pressure to the keyboard. It should easily pop out.
  3. IdeaPad Yoga 13 Charging Port Replacement: 步骤 3 中的图像 1,1
    • To remove the keyboard bezel, unscrew and remove the five screws using the Phillips #0 screwdriver.
  4. IdeaPad Yoga 13 Charging Port Replacement: 步骤 4 中的图像 1,2 IdeaPad Yoga 13 Charging Port Replacement: 步骤 4 中的图像 2,2
    • Unplug the connections from the motherboard.
    • There is a different connection for the mouse and keyboard.
  5. IdeaPad Yoga 13 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Remove the outer bezel to reveal the entire internal layout of the computer.
    • Motherboard and other internal components are now exposed.
  6. IdeaPad Yoga 13 Charging Port Replacement: 步骤 6 中的图像 1,3 IdeaPad Yoga 13 Charging Port Replacement: 步骤 6 中的图像 2,3 IdeaPad Yoga 13 Charging Port Replacement: 步骤 6 中的图像 3,3
    • Remove charging port by prying out the yellow port from the computer chassis.
    • Note the route of the cable for re-installation of the replacement.
结论
2等其他人完成本指南。
团队
IUPUI, Team S1-G2, Harley Spring 2019 IUPUI, Team S1-G2, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G2
3 名成员
创作了2篇指南
一条评论
do you have the schematic of the board?
Jorge Herrera - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,783
