简介
Replacing your motherboard can get your device running as good as new. You can also remove the motherboard if you ever want to modify the casing on your device to protect the motherboard from damage. Follow this guide to remove the motherboard.
你所需要的
Wedge the spudger into the slot of the panel on the bottom of the device.
Rotate out the panel to reveal the screw holding the device together.
即将完成!
结论
