跳转到主内容
IQ America VD-8810L Motherboard Replacement
你所需要的
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 IQ America VD-8810L Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 IQ America VD-8810L Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: 步骤 2 中的图像 1,2 IQ America VD-8810L Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: 步骤 3 中的图像 1,3 IQ America VD-8810L Motherboard Replacement: 步骤 3 中的图像 2,3 IQ America VD-8810L Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: 步骤 6 中的图像 1,3 IQ America VD-8810L Motherboard Replacement: 步骤 6 中的图像 2,3 IQ America VD-8810L Motherboard Replacement: 步骤 6 中的图像 3,3
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: 步骤 8 中的图像 1,2 IQ America VD-8810L Motherboard Replacement: 步骤 8 中的图像 2,2
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: 步骤 9 中的图像 1,1
    • Refer to this guide to desolder the speaker from the motherboard.
结论
Jackey Lau
于10/17/17注册
301 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 241
