跳转到主内容
HyperX Cloud Alpha Headband Replacement
你所需要的
  1. HyperX Cloud Alpha Headband Replacement, Headband: 步骤 1 中的图像 1,1
    • Remove the two Phillips #1 screws from the clips located on the headband.
    • Repeat on the other clip. (If you did the right side first, then do the left and vice-versa.)
  2. HyperX Cloud Alpha Headband Replacement: 步骤 2 中的图像 1,1
    • Remove the black plastic clips, freeing the metal sliding band inside.
  3. HyperX Cloud Alpha Headband Replacement: 步骤 3 中的图像 1,3 HyperX Cloud Alpha Headband Replacement: 步骤 3 中的图像 2,3 HyperX Cloud Alpha Headband Replacement: 步骤 3 中的图像 3,3
    • Remove the worn band.
结论
6等其他人完成本指南。
团队
UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S5G4
5 名成员
创作了8篇指南
3指南评论
¿Y qué hago con el cable que cruza dentro de la almohadilla? No puedo reemplazarlo si este está cruzado entre los dos extremos del auricular y dentro de la almohadilla misma.
Daniel Cetina Bastida - 回复
This guide feels like it's missing several steps. I tried taking apart the HyperX Cloud 1 which is put together pretty much the same way. As you show in Step 2 there's a cable that runs through the headband that connects the left cup to the right cup. If your goal is to replace a worn headband, you would basically have to disconnect the cable from one of the cups which is a soldered connection, draw it out through the headband, thread it back through your replacement headband, and re-solder the cable to the cup, no? That seems like an important omission.
In my case I have no soldering skills so I opted to just cut the old headband open to get the cable free, then I put it back together with just the metal sliding band and no headband.
Terry - 回复
This is just full wrong and missleading. You need to solder things to replace headband
Stanislav Shostak - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 87
过去 30 天: 351
总计 10,613
