跳转到主内容
加入维修社区 - 创建账户
Huawei Watch 2 Opening Procedure
你所需要的
  1. Huawei Watch 2 Opening Procedure, Huawei Watch 2 Opening Procedure: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  2. Huawei Watch 2 Opening Procedure: 步骤 2 中的图像 1,1
    • Remove the four Torx T2 screws (4.5 mm length).
  3. Huawei Watch 2 Opening Procedure: 步骤 3 中的图像 1,3 Huawei Watch 2 Opening Procedure: 步骤 3 中的图像 2,3 Huawei Watch 2 Opening Procedure: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the four plastic covers sitting next to the watch band holders.
  4. Huawei Watch 2 Opening Procedure: 步骤 4 中的图像 1,3 Huawei Watch 2 Opening Procedure: 步骤 4 中的图像 2,3 Huawei Watch 2 Opening Procedure: 步骤 4 中的图像 3,3
    • Insert an opening tool into the gap between the back cover and the watch case at the bottom edge of the back cover.
    • Use the opening tool to pry up the back cover of the Huawei Watch 2.
    • Do not remove the back cover assembly all the way yet—it's still connected to the mainboard.
  5. Huawei Watch 2 Opening Procedure: 步骤 5 中的图像 1,2 Huawei Watch 2 Opening Procedure: 步骤 5 中的图像 2,2
    • Carefully fold the back cover assembly to the opposite side of the two watch crowns.
结论
To reassemble your Huawei Watch 2, follow these instructions in reverse order.
4等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
250,047 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,010篇指南
3指南评论
Tengo un problema con el reloj que no me esta haciendo las mediciones de la frecuencia cardiaca, como se cambia y donde se consigue ese sensor.
Gracias
Cesar Carrillo - 回复
Hi, any ideas if you can get the rubber membrane that goes behind the buttons? One of mine has worn away so had to swap them so the main button actually worked. Just bottom button now not working..
Andy Andy - 回复
A carcaça do meu HUAWEI WATCH 2 quebrou aonde o pino da pulseira encaixa. Como conseguir uma para reposição? Grato.
Del Credere Imóveis - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 39
过去 30 天: 118
总计 7,423
