跳转到主内容
Huawei P9 Rear Camera Replacement
你所需要的
  1. Huawei P9 Rear Camera Replacement, Back Cover: 步骤 1 中的图像 1,3 Huawei P9 Rear Camera Replacement, Back Cover: 步骤 1 中的图像 2,3 Huawei P9 Rear Camera Replacement, Back Cover: 步骤 1 中的图像 3,3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Rear Camera Replacement: 步骤 2 中的图像 1,2 Huawei P9 Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Rear Camera Replacement, Fingerprint sensor: 步骤 3 中的图像 1,2 Huawei P9 Rear Camera Replacement, Fingerprint sensor: 步骤 3 中的图像 2,2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Rear Camera Replacement, Rear Camera: 步骤 4 中的图像 1,2 Huawei P9 Rear Camera Replacement, Rear Camera: 步骤 4 中的图像 2,2
    • Undo the two Phillips #00 screws.
    • Remove the bracket.
    • Mind the connector underneath.
  5. Huawei P9 Rear Camera Replacement: 步骤 5 中的图像 1,2 Huawei P9 Rear Camera Replacement: 步骤 5 中的图像 2,2
    • Release the connector.
    • Loosen the camera from the motherboard and take it away.
结论
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
5等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
211,758 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,074篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 3,542
