跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
更换华为 P9 Lite 带中框的显示屏
你所需要的
  1. 更换华为 P9 Lite 带中框的显示屏, 后盖: 步骤 1 中的图像 1,2 更换华为 P9 Lite 带中框的显示屏, 后盖: 步骤 1 中的图像 2,2
    • 从底角开始,使用三角撬片打开后盖。
    • 逆时针方向操作,一个接一个地小心地撬开塑料卡扣。
    What could you use instead of an opening pick??
    Alfredo - 回复
    Like, could a guitar pick wor? Or anything else?
    Alfredo - 回复
    A guitar pick will also do.
    Tobias Isakeit -
    what can still be used besides guitar pick
    Tarshia Thompson - 回复
    I had a hard time to open the back cover by opening pick. Then I used little, really little knife at first, and I continue to opening back cover using opening pick.
    Andy B - 回复
    Heating up aroud the finger sensor to loosen the square adhesive tape ..
    Hishamchohan - 回复
    If you do not have any picks, You can also adapt an old credit or utility card by cutting it in to thirds. Then with some fine emery or sand paper, rub a sharp point on the one edge of the card. This will help you get access to the clips that hold the rear cover on. The one i did yesterday had quite a lot of adhesive around the edge & around the finger print sensor. Another tip with an old credit card is to cut it in to narrow strips to insert in to where you have separated the cover from the frame to stop it getting stuck to the adhesive again.
    gazza667 - 回复
  2. 更换华为 P9 Lite 带中框的显示屏: 步骤 2 中的图像 1,1
    • 后盖下方有粘合剂,可将其固定在电池上,顶部装有金属板。
    • 小心右侧的柔性电缆。
    • 拧开三角撬片,将后盖拉开,并将其从粘合剂上松开。
    Most of the adhesive is around the fingerprint cell and on the battery itself. You can slowly pull the back cover from its side but make sure not to break it. Push the mediator or a longer piece of plastic under the back cover to slowly destroy the adhesive.
    Nicolas Combaret - 回复
    Slowly, slowly wins the day. Nicolas is right and comes off a charm. The most nerve wracking part of this longish repair.
    John Nordstrom - 回复
  3. 更换华为 P9 Lite 带中框的显示屏: 步骤 3 中的图像 1,1
    • 当后盖没有粘合剂时,你可以完全用手将其弹出。
    Hi! Im so sad! At the begginig of the operation i ve broken the white seal/connector that in one side is connected to the board and the other side is "glued" to the battery. Can someone help me? how can i solve this?? There is no image displayed on the screen. but there is vibration, sound, notifications... can someone help me please???
    Diogo - 回复
    What you broke is handling the NFC, and doesn’t have anything to do with the display. You probably damaged the ribbon right below the battery, since that’s what links the display to the motherboard.
    Polaris -
    Oups ! L’antenne NFC était solidement collée à l’intérieur de la coque et j’ai donc déchiré sa nappe en ouvrant la coque. Heureusement, je n’utilise pas les fonctions NFC et, à part cela, tout a l’air de fonctionner normalement.
    Michel Orban - 回复
  4. 更换华为 P9 Lite 带中框的显示屏, 主板盖板: 步骤 4 中的图像 1,1
    • 拆下固定金属屏蔽板的九个菲利普斯#00螺丝。
    • 如果螺钉顶部有任何水指示器,请将其拆下,以确保螺丝刀能够正确就位。
    Qu’est ce qu’un “indicateur d’eau”?
    chevaliernoir - 回复
    Une petite pastille qui change de couleur au contact de l’eau. Les fabricants s’en servent pour nullifier la garantie : si ta pastille indique que de l’eau s’est infiltré, tu devra payer ta réparation.
    Polaris -
    Are all the screws the same size ?
    Hishamchohan - 回复
    yes they are
    Adam M -
  5. 更换华为 P9 Lite 带中框的显示屏: 步骤 5 中的图像 1,2 更换华为 P9 Lite 带中框的显示屏: 步骤 5 中的图像 2,2
    • 不要拆下屏蔽板,它是通过连接器和电缆连接的。
    • 使用撬棒断开指纹传感器与主板的连接。
    • 将NFC天线电缆从金属板上剥离。
    can we just remove NFC antenna and dont want to install int back?
    Mohd Danial Bin Harun - 回复
    Note there are two plastic tabs at the top of the shield plate. Unlock them with a mediator, the plate will come easily after that.
    Buongiorno,
    va sostituita l'intera piastra metallica contenente il sensore impronte e la fotocamera, oppure il sensore é estraibile dalla piastra?
    Grazie
    LUIGI
    GI GI - 回复
    Yes, it is possible to remove just the fingerprint sensor from the motherboard shield. Remove the small metal plate on the inside of the shield covering the sensor and push the fingerprint sensor through from the other side.
    Tobias Isakeit -
    Grazie mille.
    GI GI - 回复
  6. 更换华为 P9 Lite 带中框的显示屏, 主板: 步骤 6 中的图像 1,2 更换华为 P9 Lite 带中框的显示屏, 主板: 步骤 6 中的图像 2,2
    • 移除 SIM 卡槽。
  7. 更换华为 P9 Lite 带中框的显示屏: 步骤 7 中的图像 1,3 更换华为 P9 Lite 带中框的显示屏: 步骤 7 中的图像 2,3 更换华为 P9 Lite 带中框的显示屏: 步骤 7 中的图像 3,3
    • 断开主板柔性电缆、电池柔性电缆和天线电缆。
  8. 更换华为 P9 Lite 带中框的显示屏: 步骤 8 中的图像 1,2 更换华为 P9 Lite 带中框的显示屏: 步骤 8 中的图像 2,2
    • 断开显示屏电缆和电源音量按键电缆。
  9. 更换华为 P9 Lite 带中框的显示屏: 步骤 9 中的图像 1,2 更换华为 P9 Lite 带中框的显示屏: 步骤 9 中的图像 2,2
    • 断开后置摄像头和耳机接口。
  10. 更换华为 P9 Lite 带中框的显示屏: 步骤 10 中的图像 1,2 更换华为 P9 Lite 带中框的显示屏: 步骤 10 中的图像 2,2
    • 把摄像头和耳机接口从它们的位置移除。
  11. 更换华为 P9 Lite 带中框的显示屏: 步骤 11 中的图像 1,3 更换华为 P9 Lite 带中框的显示屏: 步骤 11 中的图像 2,3 更换华为 P9 Lite 带中框的显示屏: 步骤 11 中的图像 3,3
    • 使用撬棒小心抬起主板。
    • 卸下主板组件。
    • 在主板的背面有一个散热垫(粉红色的橡胶状),用于散热。如果你要更换显示屏组件,并且散热垫损坏或太干,你可能需要更换新的散热垫。
  12. 更换华为 P9 Lite 带中框的显示屏, 带中框的显示屏: 步骤 12 中的图像 1,2 更换华为 P9 Lite 带中框的显示屏, 带中框的显示屏: 步骤 12 中的图像 2,2
    • 取下麦克风橡胶垫圈和耳机扬声器。
  13. 更换华为 P9 Lite 带中框的显示屏: 步骤 13 中的图像 1,1
    • 移除7颗扬声器螺丝:
    • 3颗 2.9 mm 菲利普斯 #00 号螺丝
    • 4颗 3.8 mm 菲利普斯 #00 螺丝
  14. 更换华为 P9 Lite 带中框的显示屏: 步骤 14 中的图像 1,1
    • 移除扬声器。
  15. 更换华为 P9 Lite 带中框的显示屏: 步骤 15 中的图像 1,2 更换华为 P9 Lite 带中框的显示屏: 步骤 15 中的图像 2,2
    • 拔下主板柔性电缆并断开天线电缆。
    • 将两根电缆放在一边。
  16. 更换华为 P9 Lite 带中框的显示屏: 步骤 16 中的图像 1,3 更换华为 P9 Lite 带中框的显示屏: 步骤 16 中的图像 2,3 更换华为 P9 Lite 带中框的显示屏: 步骤 16 中的图像 3,3
    • 现在取下子板。
    • 小心地剥离振动电机的触点并将其取出。
    • 同时取下下部麦克风外壳。
    Be extra careful when removing the vibrator motor ( I ripped the flex ). The flex is easy to detach but the motor is glued a bit deeper in the frame, and it’s tricky to extract. I naively thought if I applied a lever from the top side, where the flex reaches (following the ungluing of the flex cable) I could get it out, but I ripped the flex in doing so. you have to come and lift it up from the right side preferably. On the other hand if you ripped the flex, it’s no biggy. Just save the part and don’t put it back in the new frame, your phone will work but not vibrate. I always hated that thing anyway ! Otherwise you can buy a new part (non OEM) for a few euros on Amazon.
    Georgeses - 回复
  17. 更换华为 P9 Lite 带中框的显示屏: 步骤 17 中的图像 1,3 更换华为 P9 Lite 带中框的显示屏: 步骤 17 中的图像 2,3 更换华为 P9 Lite 带中框的显示屏: 步骤 17 中的图像 3,3
    • 只能沿着电池的SIM托盘边缘撬动,以保护在电池中心下方运行的显示器柔性电缆。
    • 以较小角度插入撬棒等工具,以避免折弯电池,并将其从粘合剂上撬起。
    • 将新旧部件与需要转移的小部件(如按钮或垫圈)进行比较。
    • 切勿重新安装在拆卸过程中弯曲或损坏的电池。
    Good guide, repaired without problems
    Enrico - 回复
    Really good guide - mine seemed to have a lot more glue holding things down but eventually got it all apart, One additional thing - if you need to transplant the power and volume buttons from the old frame, they just sit in an opening on the side, but be aware that they may be glued into place.
    Rich Jeffery - 回复
    I agree with the comment above. I removed the on/off and volume buttons with an old style razor blade to cut through the glue between the body and the back of the buttons. Also I would recommend buying a new battery as I totally ruined mine trying to un-stick it from the old frame.
    Tim Henry - 回复
    Same from me: everything in instruction very accurate described except power/volume buttons replacement. Most of frames comming from Chine are without these buttons and transfer from old one is required ;)
    Rimantas Grigaliunas - 回复
    Yup, a lot of glue as well and I had to bend my battery slightly. I didn’t pierce or rip it though, so I risked putting in back with the new piece. It works, but battery performance is affected. I would recommend buying a new battery and changing it at the same time. The adhesive is already in place on the new frame, so no need for double sided tape.
    Georgeses - 回复
    Also volume up down and power buttons were not on the new frame. I had to get them from the new frame and they were glued were strongly.
    Before you consider taking them out, make sure to remember how the little gray plastic cover on top was put (that bit was not glued by the way, it’s the actual button underneath which is), since you may have a headache putting it back in place on the new frame. You will know you got it right when all three buttons “click” when all is done.
    As for the ungluing, the only way I could get them out was by first ungluing the screen with iopener/suction handle/picks (although my screen was way too broken for that too work, in the end I had to push through the broken screen by a small hole in the old frame, where the battery was before).
    Georgeses - 回复
    Once you get the screen off the old frame, there’s a small black tape where the buttons are on the other side. Remove it first, and from there you can see the buttons and push them out. You have to cut out the glue first though. I used one tip of the tweezers since they were thinner and stronger than the plastic spudge and “sawed” between the buttons and the frame, that’s where the glue is. Be careful to saw between the button and the frame and not between the circuits and the buttons (orange layer and metal piece), or you will wreck it. Also be careful when you reach the middle between the two volume buttons (I think, just check from the inside) since that is where the circuits merge into the flex that connects to the motherboard.
    Georgeses - 回复
结论
请按逆序重组你的设备。
39等其他人完成本指南。
由衷感谢以下译者:
en zh
90%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,781 声望
创作了188篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,082篇指南
7条评论
I finished to replace the display yesterday and everything is perfect , thanks ifixit
husam faraj - 回复
i replaced the display but the touchscreen doesn’t work
Michele Rappazzo - 回复
You can try to reopen the phone and check if the flex cable is plugged in correctly or if any cable is ripped. If you can’t find any damage and all cables are plugged in correctly it’s possibly an issue with the replacement part.
Dominik Schnabelrauch -
Hi, could you show how to replace the power button flex cable for a P9 Lite 2017? I would be greatful.
szaszisti - 回复
my powerbutton connection is also missing…
lorenz_untersulzner -
Ho riparato il cellulare e realmente la guida è fatta molto bene, Grazie!
Ermanno Marota - 回复
Great guide ! I added a few comments under the relevant steps for the following issues (they were my doing though, the guide is great) :
STEP 16 Be extra careful when removing the vibrator motor as it is rather easy to rip the flex.
STEP 17 I had to get the volume up/down and power buttons from the old frame and that proved tricky (see my comments under step 17). Mind you that is not the outer plastic button but the inner metal button and circuits. You will know it’s not there by pressing the buttons to see if they “click”.
*I STRONGLY RECOMMEND BUYING A NEW BATTERY TOGETHER WITH THE SCREEN* I was able to remove my battery without wrecking it but the slight deformation still affected battery performance in the end (a lot). I highly doubt it is possible to do this repair without harming the battery.
Georgeses - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 38
总计 25,150
